Re: Super A Quits When Hot
Posted by Brownie 450 on July 05, 2009 at 05:00:12 from (216.51.158.133):
In Reply to: Super A Quits When Hot posted by DEEPNHOCK on July 03, 2009 at 19:05:19:
Lets think about valves hanging up when the engine gets hot. Maybe you should try a small amount of top oil or other upper cylinder lube--diesel fuel?
