You can mount a CHAR-LYNN power pac system on the belt pulley then using the up side of a two way cycl to lift a blade by putting the cycl in place of the third link. I have used one on a B for many yrs. The system has single and two way hy with built in control valves and pum and resivour all in one unit. Only need to run them 700 rpm 10gal flow and 1000 psi real neat units. I use two of them on two tractors split wood raise the wheel disc,loader,front corn planter or anythin needing hy system.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
