Re: no oil
Posted by Bigdog on July 05, 2009 at 06:50:39 from (71.64.18.18):
In Reply to: Re: no oil posted by K-Mo on July 05, 2009 at 06:31:22:
If you remove the oil filter cap you will note a small hole inside the filter housing. You can use that hole for priming the pump too. (just in case the plug on the rear of the block is stubborn)
