Re: battery ground
Posted by ScottyHOMEy on July 05, 2009 at 10:25:27 from (70.105.224.12):
In Reply to: battery ground posted by fiddlin' farmer on July 05, 2009 at 10:09:49:
Could be anything, fiddler and, as useful as a manual is for lots of other things, it won't help you much on this one.
From the factory, they were all 6v positive ground. But many have been altered to 12v, which is customarily but not always negative ground.
How many caps on your battery. Three would be a 6v, six caps would be 12v. Alternator (negative ground) or generator (could be either.)
If you have a battery ignition with an external coil as opposed to a magneto, look at the two terminals for the small wires on the coil. One will be marked "+" and the other "-" The marking on the one with the wire that runs to the distributor will indicate your ground in that case.
