Re: Farmall super M
Posted by Hoosier Mark on July 05, 2009 at 18:25:02 from (64.12.116.73):
In Reply to: Farmall super M posted by Bill No Mn on July 05, 2009 at 15:59:43:
Also check the sediment bowl fitting inside the gas tank. I had a 1950 "M" that would clog the opening into the sediment bowl inside the gas tank. It would allow just enough gas to start the tractor and run just a little before it would die, just like if it vapor-locked. Hope this helps!
