Re: IH414 Main driveshaft needle bearing spacer
Posted by Szrachnor on July 05, 2009 at 20:33:05 from (68.118.189.13):
In Reply to: IH414 Main driveshaft needle bearing spacer posted by stevemat on July 05, 2009 at 06:50:58:
If you go to the online parts catalog under B-414, either gas or diesel, you will find it under "transmission gears and shafts". Goto part #15 which is the pilot bearing, there are 4 options available, under the 4th option you will see part number 3068278R1 collar, pilot bearing. I believe this is the piece you are looking for.
I will also say that I have probably rebuilt about 10 of these transmissions and I have never found the washer myself, or put one back in and none of them have ever failed.
-Leon
