Re: IH 424 air getting into hand pump?
Posted by Bob on July 06, 2009 at 15:12:07 from (69.178.228.68):
In Reply to: IH 424 air getting into hand pump? posted by Mark2890 on July 06, 2009 at 13:18:30:
1.) Check/clean pump suction screen attached to fitting at lower RH side of 3-point casting. (Have to disconnect line and remove fitting/screen from casting.)
2.) Could be a pinhole leak in suction line or a bad pump seal (and possibly bearing).
3.) I have a power steering manual for the tractor. I'll take a look later tonight and see what else may be suggested.
