Posted by Chris NW Ind on July 06, 2009 at 16:30:03 from (64.136.26.235):
In Reply to: Rear end whine posted by Pete Ward on July 06, 2009 at 15:11:55:
If it is the pilot bearing, don't neglect it. It can, and will, tear up your constant mesh gears. Before you pull the deck, just yank the belt pulley gearbox/delete cover. You can see the upper constant mesh and input shaft. You may be able to detect your problem. When in neutral the only things turning are the input shaft and the countershaft. Either way you can do all the necessary repairs without splitting.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
