Re: flames coming out of exhaust manifold farmall m
Posted by jbp on July 06, 2009 at 18:17:49 from (64.57.160.59):
In Reply to: flames coming out of exhaust manifold farmall m posted by tasha w on July 06, 2009 at 18:10:42:
Sounds like the timing got retarded somehow,now the fuel is burning in the manifold instead of the cylinders. Bet theres a noticeable loss of power too. Joe
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
