Re: CHANGE ENGINE FROM LP?
Posted by mkirsch on July 07, 2009 at 05:30:31 from (64.80.108.56):
In Reply to: CHANGE ENGINE FROM LP? posted by DONALD SCHNUPPER on July 06, 2009 at 14:27:23:
Too many parts required. You may as well buy a gas 400 from the beginning.
Why do you want to convert it back? LP is clean and efficient. The engine will last practially forever with none of the problems that old gasoline engines have with modern gas. Propane has always been propane. Can't say the same about gasoline.
