Re: Restoration Price
Posted by labman98 on July 07, 2009 at 18:22:37 from (216.111.223.2):
In Reply to: Restoration Price posted by labman98 on July 07, 2009 at 15:41:46:
Well I have been restoring tractors for about 3-4 years now, I have done 8 I believe and it seems that I am undercharging. I fix all leaks, tires if needed, remove all tires and put on stands. Remove any sheet metal and get down to basically the chassis. I sandblast the whole works and any pieces and then prime and paint. I then assemble it painting all bolts/nuts seperately before I install. I have been charging anywhere from 600-1000. The paint is very very good as well. The tractors that I have done usually are some of the best looking at the tractor rides. But I am just not sure what to charge, or what others are charging. Thanks for any info
