Re: adjust carb.
Posted by CNKS on July 07, 2009 at 18:49:21 from (216.144.104.128):
In Reply to: Re: adjust carb. posted by Charlie Gascich on July 07, 2009 at 14:36:11:
Cleaning the carb means disassembly, soaking in REAL carb cleaner overnight if possible and blowing out with compressed air. Float setting is 1 27/32 from the bottom of float to top of gasket, meaning the float is essentially level. Set the idle speed so that it runs smoothly, then turn the idle mixture screw in until it stumbles and out until smooth. Then at wide open throttle and tractor warm turn the main screw in until it stumbles then out until smooth plus maybe 1/4-1/2 turn. Move throttle to low idle and advance rapidly -- rpm should increase rapidly to full rpm. You may have to repeat setting the idle and main jet a couple of times. If this does not work, you have other problems.
