Re: Farmall M or Super M
Posted by D Slater on July 07, 2009 at 19:19:11 from (72.65.152.136):
In Reply to: Farmall M or Super M posted by FarmallZach on July 07, 2009 at 19:00:53:
If its a real late M the only way to tell is by the engine and transmission gear speeds. SM before the battery box was located under seat used the same gear shift as a lot of M tractors. If its a M engine the casting # on engine block will only have 4 numbers, unless it was replaced.
SM engine will have 6 number casting, also should have C-264 above oil filter housing. If your other M has the standard fourth gear a SM will be almost as fast in 3rd gear with same tire sizes. If the carburetor is original the choke lever will be on engine side of SM compared to outside on the M.
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
