Re: 400 Electrical Conversion - I Ain't Gettin' Something...
Posted by Janicholson on July 07, 2009 at 19:27:57 from (64.61.211.124):
In Reply to: 400 Electrical Conversion - I Ain't Gettin' Something... posted by Crazy Red Power in SE-WI on July 07, 2009 at 17:16:52:
All is well till you get to the word "Now".
Run a wire from the #1 post of the alt to a marker light bulb (by its self), or the marked end of a 3 amp 100piv power diode. the other terminal of the light bulb or non marked end of the diode goes to the same terminal on the key switch, or the coil + terminal(if it has a 12volt coil no external resistor needed), or to the Key side of the external (ballast) resistor (it needs a ballast resistor if it has the original 6v coil, or a 12v external resistor required coil).
This allows the alt to know when to charge, and when to stop charging.
The original VR should be discarded (or given a rest under the bench.
The green wire is not used.
The resistor is not needed if the coil measures twice the resistance across its little terminals than a 6volt coil. It will work well.
JimN
