Re: Farmall H 1947
Posted by Andy Motteberg on July 07, 2009 at 19:41:48 from (4.143.223.192):
In Reply to: Farmall H 1947 posted by Kyle Frantz on July 07, 2009 at 18:32:32:
We had the transmission top cover off Dad's H to replace 2 broken gears. Put the cover back on using Permatex Ultra Black silicone gasket maker, Ultra Black is more oil reistant than the blue. Worked out good, no leaks.
