Re: 1086 Transmission
Posted by pete 23 on July 07, 2009 at 20:51:22 from (173.87.14.132):
In Reply to: 1086 Transmission posted by JD Farms on July 07, 2009 at 19:54:54:
You will find that the high low shift fork has come off the shift rail. Pulling the range trans cover however involves the reverse shifting shaft that extends downward and you need to pull cover off side also. If you have that extra fuel tank along side of course that hides the side cover so that needs to come off. (there was a special tool released by IH so you didn't have to pull reverse shifter shaft but I still prefered to pull side cover). When you get that far what you find will determine next steps to take.
