Re: Farmall H 1947
Posted by Dave in CT on July 08, 2009 at 05:52:56 from (69.182.106.211):
In Reply to: Farmall H 1947 posted by Kyle Frantz on July 07, 2009 at 18:32:32:
You can find large sheets (36" wide) of a heavy (1/8") fiber gasket material and cut your own gasket. I've used this material for several applications and it works great. I believe I got mine from MSC but I it's available all over.
