Re: identify tractor
Posted by Cue P. on July 08, 2009 at 08:58:57 from (74.10.243.130):
In Reply to: Re: identify tractor posted by gene bender on July 07, 2009 at 23:54:23:
i think he means for a "city girl" knowing where to get implements for it may be harder unless it comes with the original equipemnt. as you know modern 3pt stuff will not adapt unless you also know you need a 3pt hitch adapter etc etc.
