Re: H water pump pulley, belt adjustment part question
Posted by GeneMO on July 08, 2009 at 13:14:17 from (65.174.132.35):
In Reply to: H water pump pulley, belt adjustment part question posted by Wild Bill on July 08, 2009 at 11:39:41:
If you get it off and cleaned up, I wouldtn't be afraid to weld it.
I have welded pulleys before using Nickle rods with a stick welder.
I would just weld about an inch at a time, then between welds Peen the heck out of it with your chipping hammer.
Other than the labor of putting it back together and trying it, you wouldn't be out much to try it.
Good luck, Gene
