Re: Cub Carb
Posted by Jeff Z. on July 08, 2009 at 13:45:01 from (74.76.2.129):
In Reply to: Cub Carb posted by Ted A Neis on July 08, 2009 at 13:27:26:
It sounds like it could also be a gas flow problem. I would start at the tank and work back to the carburetor and make sure you have a stong flow. If you have a drain plug on the bowl of the carburetor you should get a fast flow out of it. Could also be a restiction in the carburetor.
To check for an air leak do this with a cold engine. When engine is at an idle spray choke cleaner around the carburetor and intake manifold.
If there is a leak it will suck in the cleaner and you will hear the engine act up .
