Re: tractor pull
Posted by spiffy1 on July 08, 2009 at 19:32:08 from (70.41.135.42):
In Reply to: tractor pull posted by Ksfarmmer on July 08, 2009 at 05:12:12:
If there is a weak spot on the tractor [either by design or extensive field work] I'd say the sled would cause a break down first - else field work would cause more wear [10-100X time under load for exhibition; 100-1000X the hours for field use] - the former applying "max load" for a very short time; the latter anywhere from nill to near max for much longer times. Which constitutes abuse? Whichever you're engaged in when the breakdown occurs! :lol:
To the original question; beat's me! Allis does always have quite a power to weight ratio, but I don't think the H has anything to be ashamed of with a good balance of power/weight.
