Re: Wheel weight question
Posted by wayne in mn on July 08, 2009 at 21:14:01 from (68.119.29.233):
In Reply to: Wheel weight question posted by Machine249 on July 08, 2009 at 18:29:47:
Are you sure you mean sodium?? Calcium chloride is the usual liquid in the tire.
Still heavy & dangerous to move without a hoist.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
