Re: hyd valve seal on MH pony
Posted by Janicholson on July 09, 2009 at 07:34:54 from (64.61.211.110):
In Reply to: hyd valve seal on MH pony posted by smcIN on July 09, 2009 at 06:43:06:
A thin (.010") gasket made from felpro fiber based material should be OK. Make sure the cover is flat (flat polish it using 100 grit Silicon carbide paper with rotary movement on a piece of flat glass)
and leave it at the 100 grit smoothness. Use a very thin skiff of copper coat spray on both sides of the gasket letting it dry to touch before installing on the application.
Another solution is to have it grooved for an Oring, but that would cost a few bucks. JimN
