Re: Farmall H : rotor will not line up with cap
Posted by El Toro on July 09, 2009 at 08:17:39 from (205.188.116.73):
In Reply to: Farmall H : rotor will not line up with cap posted by scott andrews on July 09, 2009 at 07:11:14:
Does it still run? If it has a distributor check the timing with a timing light to see if its off. If its off rotate the distributor until the timing marks are aligned. Bring No1 piston to TDC on the compression stroke then see if the
rotor is aligned with No1 plug wire. Hal
