Scott - A couple other things to look at before you begin tearing into the engine:
1 - The distributor centrifugal advance may be stuck in the "full advance" position. The rotor should rotate about 15 - 20 deg clockwise with a light twist of the fingers and spring back when released. If it does not go inside the distributor and look for broken advance springs and/or a frozen flyweight and cam mechanism.
2 - Someone had the distributor apart and didn't properly re-time the distributor drive shaft to the distributor gear when they put it back together. (Gears are inside the housing where the distributor mounts)
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
