Re: Farmall H : rotor will not line up with cap
Posted by Janicholson on July 09, 2009 at 08:34:17 from (64.61.211.110):
In Reply to: Re: Farmall H : rotor will not line up with cap posted by scott andrews on July 09, 2009 at 08:19:46:
In the small housing that the distributor is attached to, there are gears. These can fail They are 2:1 reduction gears. If the distributor centrifugal advance weights or springs fail, it can jamb, breaking teeth. (worth a look) They have alignment marks. and need to be correct. If they are good, it may be that the advance mechanism is toast in the distributor. Dis assemble it (point backing plate first) to look/see. JimN
