Zach, look forward on the side of engine about the same level as where the C-264 was found. There should be a small flat that gets machined flat when the side cover surface is machined. You should find the engine serial # stamped in there. First Farmall SM tractor engine for 1953 was 25432 and around a 800 lower for a Louisville model. Thats calender year, so if the engines original that may give you a idea. If its higher the tractor would be a 53. If lower it would fall under the question as to when IH started there year they call 53. (fiscal year or not) If the serial # is much higher than a few hundred over 113000 the engine could have came from a later tractor that used a C-264. If no serial # it could be a replacement part.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
