That isn't a book. The two seals are replacable from under the tractor, as is the clutch PP and disk. Take apart the coupling at the transmission. (take a photo to assure correct assembly) Remove the Throwout components. remove the drive yoke and the retainer and there it is. The bottom seal is taken out after the drive coupling is unscrewed with a hard square steel bar (lefty loosy) The clutch is toast. Clean the oil off of everything, and be sure to replace the pilot bearing in the center of the F/wheel. There are pictures in the archives, as well as a vast number of posts on this topic. Good luck JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
