Re: Farmall H : rotor will not line up with cap
Posted by pete 23 on July 09, 2009 at 20:22:03 from (173.87.14.132):
In Reply to: Farmall H : rotor will not line up with cap posted by scott andrews on July 09, 2009 at 07:11:14:
You say tractor was running so this is probably not the case, but , I have seen a jillion of these battery ignigion units (IH style) where some one used a screw to hold stationary point that was too long and it just tears heck out of inside of distributor, sometimes striping the gears, shearing the pins securing distribtor gear, and tearing up the whole advance mechanism. Also, have seen just rusted shaft in distributor causing pin to partially shear. You need to pull distributor and work your way inward to determine problem. Could be most any of the things others have suggested.
