Re: Farmall B conversion
Posted by bjb in Tx from Ne on July 10, 2009 at 05:35:52 from (141.197.12.183):
In Reply to: Re: Farmall B conversion posted by Bob M on July 09, 2009 at 08:07:58:
Be careful...I think they make Positive ground alternators too. I burnt up one on a TD6 crawler b/c the starter wasn't turning and thought I had the ground wrong. Switched it to negative and burnt up the bridge rectifier (diodes that turn the AC to DC) in the alternator.
