Re: H distributor Scott Andrews
Posted by Ted in NE on July 10, 2009 at 07:43:17 from (74.85.105.110):
In Reply to: H distributor Scott Andrews posted by Ted in NE on July 09, 2009 at 20:30:45:
Bob, Thanks for the reply. Found the problem. The cam block on the spring loaded point arm is on backwards. Makes the points just break when rotor is BETWEEN 1 & 3 towers on the cap. Found an old set I had saved to compare it with. Hope Scott gets this message, had the same problem. Must be the new China made CNH points.
Ted
