Re: Water leak on 560 Diesel
Posted by pete 23 on July 10, 2009 at 10:38:22 from (173.87.14.132):
In Reply to: Water leak on 560 Diesel posted by Old School on July 09, 2009 at 19:24:58:
Frost plug is in block , problem is that the timing gear cover and plate behind timing gears cover over half of the frost plug. I have seen and heard of different ways to repair this, some work, some don't. Right way is to remove all parts covering it but that is a major project. Camshaft gear is biggest problem. If you remove gear without shaft then you need a special tool to install gear so as you don't knock rear frost plug out of rear of block. More fun. Your call.
