Re: Water leak on 560 Diesel
Posted by Owen Aaland on July 10, 2009 at 12:39:28 from (65.165.246.156):
In Reply to: Water leak on 560 Diesel posted by Old School on July 09, 2009 at 19:24:58:
It looks like your new water pump has a problem. The hole in the bottom of the pump is to allow coolant to leak when the seal fails. Otherwise the coolant would enter the bearing and destroy it which could result in more problems.
If no lubricant is used between the seal and the impeller when the pump is assembled, running the engine with no coolant can ruin the seal very quickly.
