Ted in NE said: (quoted from post at 05:17:25 07/10/09) Scott, I just run into the same problem. Really had me going for a while. Check your OLD moveable point arm with the new one. Must be the new style Chineese CNH points. The cam block is on backwards. Hav'nt tried to see if it cn be turned around yet. Hope this helps.
Ted
The difference between the four cylinder movable arm and the six cylinder movable arm it the way the rubber block is installed. It sounds like you got the wrong one. Also, the six cylinder adjustable contact has a curve where the four cylinder one is just "L" shaped.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
