There is a fault in the primary wiring of the tractor. This means that there is no voltage getting to the coil when the key is on. The system is getting its voltage from the Alternator. Not correct. Use your test light to trace the voltage from the starter relay (little can on starter) to the amp meter, from the amp meter to the ignition switch, from the switch to the coil. There is a break some where. The #2 terminal should be attached to the Big Bat post on the Alt. The #1 post is connected to the Diode. There should be no voltage on the #1 terminal when the tractor is not running, key off. This could be part of the problem, If you measure 12+ volts at #1 terminal the regulator in the alternator may be bad. Are you sure it is a 10SI alternator? JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
