Sure does look like it could be coming from the weep hole on the pump---unlikely, though that both pumps are leaking the same. Where did you buy the pump? Can't remember---does the pump have a tin plate on the back, or is it just the casting bolted up? That's been years since we did our 560's pump--mind gets a little fuzzy.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
