Re: No Luck With The 400 Wiring...
Posted by mkirsch on July 10, 2009 at 21:59:50 from (64.80.110.13):
In Reply to: No Luck With The 400 Wiring... posted by Crazy Red Power in SE-WI on July 10, 2009 at 15:02:35:
Crazy, the starter, lights, and coil should get power even if no alternator is installed at all!
Power to the lights comes straight from the battery through the Ammeter.
Power to the coil comes straight from the key switch when it is in the ON position.
The starter is a little more complicated. Power goes from the battery to the solenoid to the starter via the big wire. The solenoid is activated by the key switch when you turn it to the start position like a car.
