Re: Water leak on 560 Diesel
Posted by Owen Aaland on July 11, 2009 at 14:08:35 from (65.165.246.156):
In Reply to: Water leak on 560 Diesel posted by Old School on July 09, 2009 at 19:24:58:
I have seen seen several pumps leak out the weep hole after they have been rebuilt. The cheap kits use an impeller that just has a machined surface for the seal to ride on. Any imperfections will allow coolant to leak out. The IH kits use a ceramic disk with a rubber seal pressed into the impeller. If the ceramic cracks the pump will leak. It is also possible that the bellows in the seal itself are damaged.
Verify that the leak is indeed coming from the weep hole. If it is you have a defective pump.
