Posted by Owen Aaland on July 11, 2009 at 14:16:33 from (65.165.246.156):
In Reply to: H belly pump posted by DK44H on July 10, 2009 at 22:04:47:
The cap over the relief valve is used to kick the lever out of the lift position.
When the rod is pulled all the way back it should stay there until the cylinder reaches the end of the stoke. When the oil flow stops, the relief valve opens and the caps pushes against the detent arm allowing the outer arm to move forward and pull rod to drop down to the stop pin.
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
