In addition, I will tell you what happend to me once with my Super H. I drained the rear end to change fluid. On the advice of someone here on the forum, I pushed an extendable pencil magnet in the drain hole and swiped it all around - pulled out pieces of bearing cage and one ball bearing. Uh-Oh! I reswiped severl times and pulled out more bearing cage material. I kept on until the magnet was coming out basically clean. I had quite a pile of metal.
In an abundance of caution I pulled the entire deck off the tractor and found that the particles and ball were the remains of an "old wound" which had already been repaired and that all the bearings were okay. I felt like I had wasted my time and effort, but then again, I really wasn't going to be happy if there were problems lurking that hadn't bitten me yet. So, I still gained peace of mind, knowing there were no other loose balls in there and that the bearings were fine.
Point: You may need to use a pencil magnet in the drain hole to find all the missing bearings. Plus, it is a good safety check. mike
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
