Re: how manyfoot pounds to torque an f-20 head
Posted by Andy Motteberg on July 11, 2009 at 18:04:34 from (4.143.223.254):
In Reply to: how manyfoot pounds to torque an f-20 head posted by jim moles on July 10, 2009 at 20:45:26:
F-20 head should be torqued to 90 ft lbs. The valves with warm engine shouuld be set to .009". Spark plug gap, .025".
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
