Re: farmall m leaking water around head bolt
Posted by Janicholson on July 11, 2009 at 18:10:02 from (64.61.211.98):
In Reply to: Re: farmall m leaking water around head bolt posted by rwmjr on July 11, 2009 at 13:52:48:
Lower the coolant level below head.block line.
Remove only the bolt that leaks and put #2 permatex on the clean threads. Screw it back in place and torque to spec. Then run it. Do only those that leak. It may be a one pony show. JimN
