Re: A Question Of Ground....
Posted by John G. Hasler on July 12, 2009 at 05:20:49 from (174.124.18.71):
In Reply to: Re: A Question Of Ground.... posted by old on July 11, 2009 at 20:54:05:
> The law also states that any place as far as
> electricity goes is the same point. I.E. if you
> ground it at the starter or you ground it any
> place else the law of electricity says it is the
> same.
Jim is right. The iron has resistance, as does every bolted connection between castings. It's a very small amount of resistance and doesn't matter for the small currents drawn by lights and such but it can cause significant voltage drop with the 400+ amps drawn by the starter. Bolting directly to the starter is best, assuming that the battery cables are large enough.
> Sorry I'm an ex ET from the navy and in the
> past I fixed computers etc.
I'm an electrical engineer. In the past I designed computers etc.
