Re: simplified wiring for IH 656
Posted by TractormanNC on July 12, 2009 at 12:18:08 from (209.42.180.126):
In Reply to: simplified wiring for IH 656 posted by GwenI on July 12, 2009 at 10:33:48:
Your operators manual should be your first source for info. Good wiring diagram in it.
Now as to some of your questions,
There is no "fuse box" only a single fuse holder that feeds the light switch.
The key switch feeds the fuel gauge, start switch button, and if you have them the alternator excite terminal and the air restriction indicator.
The glow plugs are wired from the starter solenoid to the glow plug push button and then to the glow plug junction block on the cyl head.
There is also a clutch safety switch and I am not going to tell you how to bypass it.
HTH
