Posted by Chuck's Repair on July 12, 2009 at 15:07:38 from (162.40.106.125):
In Reply to: 1486 rear end posted by joe 1971 on July 12, 2009 at 08:19:03:
I have not worked on many differential locks however if I remember correctly if the differential lock fails it will have the simptoms you are experiencing. I would check that out before I did any major work Chuck
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
