Replacing Front Transmission Oil Seals
Posted by David Goode on July 13, 2009 at 08:09:08 from (69.19.14.33):
What is the correct procedure when replacing the front two transmission oil seals on a Super M? It orginally had the belly hyrdaulic pump and there is a bad oil leak from the drive shaft coming out of the transmission. I see that the drive shaft is a nut and I'm not sure if it has right hand or left hand threads. Also how do you go to replace the main oil seal on the linkage/drive shaft from the clutch to the transmission? Thanks
-David Goode Coggon, IA
