Posted by glennster on July 13, 2009 at 11:19:35 from (99.135.95.186):
In Reply to: A IH posted by WISC BOB on July 13, 2009 at 09:31:43:
if the oil change dont work, get a new pan gasket and oil pump lower cover gasket from your friendly i-h dealer. drop the pan and then pull the lower cover off the pump. careful, a spring and plunger will drop out, be sure to get them back in the right way. look at the inside of the cover, it prolly has grooves worn in it from the pump drive gears. if so, get some emery cloth and a sheet of glass, lay the cloth n the glass then sand the cover using figure 8's till smooth. then reinstall. works good on the a and b motors
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
