Re: C oil pressure
Posted by mattofvinings on July 13, 2009 at 19:37:57 from (198.208.159.20):
In Reply to: C oil pressure posted by Russ from MN on July 13, 2009 at 19:26:31:
Before you get into bearing clearance issues, I'd have the pan off and look at the oil pump's gear and end clearances and pressure-relief spring-ball. A lot of the characteristics of the oil system's performance are "setup" right there...and a lot less work than a full micrometer and plastigage teardown.
