if you are able to do the seal then you may as well check or set the static timing to were it should be. 560 is 3 degrees btdc.turn engine over , # 1 cyl. on compression till pointer lines up with 3 degree mark. shut off your fuel at tank and remove timing window cover on side of pump.then see if the two marks are lined up. if not alighned loosen the two pump mounting bolts and turn pump either way to alighn marks and tighten bolts. you can do this last, but i would alighn the pointer to 3 degrees before removing pump and go ahead from there.you dont know if it is set to spec now and scribe lines arnt totally accurate.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha
... [Read Article]
Latest Ad:
[More Ads]
