Re: Farmall 706 Transmission (H-L-N-R)
Posted by MN Scott on July 13, 2009 at 19:59:32 from (206.9.216.71):
In Reply to: Farmall 706 Transmission (H-L-N-R) posted by Koeppel on July 13, 2009 at 06:44:49:
Sometimes you have to bump the clutch pedal out a bit to give the trans a tourque release to let it shift. Run thru the adjustments but even with everything in perfect adjustment you have to give it a torque release from time to time. After you run it for awile you will get the hang of it. I can shift my 706 as fast as my 1066. Main thing is to never force it!
